location for heater control valve?
Old Nov 6, 2009 | 08:34 AM
cal30_sniper's Avatar
Car: 88 GTA/86 C20 Burb/91 325i
Engine: L98/454/M20
Transmission: 700R4/NV4500/Getrag
Axle/Gears: 3.27 9-bolt/3.73 14 Bolt/3.73 IRS
Hey all,
I'm getting ready to put the heater control valve back in my heater hoses (was gone when I bought the car). This is the piece that has a line in, a line out, and a vacuum nipple on top that is spliced into the heater hoses. My only question is, which hose does it go in? The hose from the heater core to the water pump, or the hose from the heater core to the intake?
I've got a carbed LG4 car, so it's different from the fuel injected setup.
Thanks for the help, I'm trying to do this tonight and just realized i didn't know where it goes.
-Levi
Old Feb 11, 2010 | 04:22 PM
defaria27's Avatar
Car: 1992 Camaro Z28
Axle/Gears: factory 373
Re: location for heater control valve?
hey did you ever figure it out???????? because im having same questions now
Old Feb 11, 2010 | 06:20 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Well Semper Fi sir...
I'm a little confused by your control valve description.
The models I'm familiar w/ (90 & later) have 3 coolant
hose connections, and a small vacuum port connection.
One inlet, two outlets, with vacuum control of which
outlet is active. In combination with a T connector,
hot water is routed from an intake manifold output,
either through the heater core, or directly back to the
radiator. If your control valve has only 2 hose connections,
its either open or closed, and overall hose routing is
different. If you can post some pics of valve, and engine
compartment, I can probably help you recover.
1992 Trans Am
May 10, 2023 07:19 PM
The_Phoenix
Feb 4, 2016 07:10 AM
lakeffect2
Aug 23, 2015 08:44 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
