AC vacuum line......thingy
Old Jan 25, 2010 | 04:08 PM
Vortec_Formy's Avatar
Car: 89 Formula/94 z28
Engine: Vortec 350/ LT1
Transmission: WC T-5/ 4l60e
Axle/Gears: torsion posi 3.23s/auburn posi323s
Hey everyone, my 89 formy had the original 305 pulled in favor of a carbed vortec 350, my question is.....the ac work but only blows through the defrost like the heater does, i looked under the hood and one vacuum line runs to the egr valve satelite looking thingy and theres another vacuum line just sitting there, where do I run it? to the carb?
Old Jan 27, 2010 | 02:28 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Vacuum Room
Yes if the carb has a vacuum port, that’ll work.
Or you can use any source of vacuum.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog or “running” lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime and the nitwits that need headlights for a little rain
Old Jan 28, 2010 | 06:01 AM
Re: Vacuum Room
thank you, i was thinking that but didnt want to mess anything up without asking, btw, nice signature
Old Feb 3, 2010 | 01:09 PM
jimcairns's Avatar
Re: Vacuum Room
I have two small black flexible tubes coming through the firewall near the AC/Heater. What are they for and do I need to use them? I have a Ram Jet 350.
Old Feb 3, 2010 | 01:36 PM
Re: Vacuum Room
I dont know what they are for but I think they deal with vacuum for the ac/heater. one I think goes to the egr valve and the other to a vacuum on the intake. I think
Old Feb 10, 2010 | 04:41 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Re: AC vacuum line......thingy
Negative on the EGR connection, unless its a T fitting
between manifold vacuum, and the EGR controller.
(EGR valve should have a DEDICATED line from the controller.)
The 2 firewall vacuum connections are
-- input a vacuum source.
The dash control routes vacuum to the diaphragms that control
cabin air flow.
-- output to the heater control valve.
(A popular thing to rip out by the purists, to "clean-up" the engine bay.
in which case it should be sealed, or you'll have a vacuum leak
when you try to activate the heater.)
Off the top of my head, I can't remember how to identify which is which,
and I'm currently 300 mi's away from my project.
Good luck.
Old Feb 11, 2010 | 10:58 AM
jimcairns's Avatar
That is the best answer I have been able to find anywhere. Thanks.
Where is the heater control valve located? Perhaps I can use that to figure out which one is which. If I want the heat and AC to work as they orginally did, do I just need to connect both of them to vacuum?
Old Feb 11, 2010 | 05:34 PM
thx for the hijack, lol just kidding, if I connect one of the hoses to the heater control valve and the other to a vacuum on the motor like on the carb will it cause the air to come through the normal vents and not the defrost?
Old Feb 11, 2010 | 05:49 PM
Heater control valve is on the passenger side of the eng. compartment,
identifiable by three hoses conected to it. For TBI engines, one hose
comes from the back of the intake manifold, one hose comes from the
heater core through the firewall, & one hose goes to the radiator.
Its a vacuum operated valve that routes hot water either to the
radiator, or through the heater core. TBI engines have a similar
configuration, but I don't know the exact hose connnection points.
Connecting both firewall vacuum lines together will probably adversely
effect overall heat-ac control function. To supplement my original
response below, the (firewall) input vacuum source is connected to the
dash control, which routes the vacuum to various diaphragm controls
to direct airflow generated by the fan. So without input vacuum,
air will only go to the default location, which I believe is the defrost vents.
If you can post a picture of what you have, and what does/doesn't work,
I can probably help you get where you want to go.
Old Feb 11, 2010 | 06:02 PM
Vortech got your response in while I was typing the response to jimc.
So Vortech, the not so short answer is yes, IF
-- you get manifold vacuum connected to the correct firewall connector.
-- the dash control switch still works properly.
As I sit here thinking, I recollect something about the firewall connectors,
before I had to repair mine. (Long story, )
Originally, these are hard hard plastic lines, with rubber boot connectors.
The longer line is the output to the control valve, and the shorter one
is the input, connected to a manifold vacuum source.
(To repair mine, I put small barb connectors through the firewall, and
will then use standard rubber vacuum lines.)
Old Feb 11, 2010 | 06:20 PM
oh alright cuz everything is hooked up except one small vacuum line from the firewall which from what you say I need to possibly hook up to the carb then??
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
timonator
Sep 30, 2015 12:52 PM
dusterbd
Sep 29, 2015 08:40 AM
