No power to a/c compressor
Old Aug 20, 2009 | 06:50 PM
visionpb16's Avatar
I have a 1991 camaro 5.7 TPI. My a/c compressor doesn't have any power. I checked both the connections with a voltmeter and both were 0V. I checked the a/c fuse and it is fine. One thing that I think might be the cause is I wired both my radiator fans together so they both run the temperature switch, so the a/c doesn't have to be on for both to run. But to do this I had to cut the wire from the a/c radiator fan relay. Does that relay have to be hooked up completely for the a/c to work or is it just a fan relay?
Old Aug 26, 2009 | 01:32 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
AIR REPAIR
Make sure your GAGES fuse is good.
Make sure your PRESSURE CYCLING SWITCH is good.
Check for AC relay closing.
If it doesn’t close make sure the ECM is grounding pin F1.
If it closes you need 12 volts on pin A.
If you have 12 volts on pin A of the AC relay the compressor clutch should actuate.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. They look dorky. Turn em off slow pokes.
How bout those dorks too scared to drive without headlights on in the daytime!
evilstuie
Apr 14, 2016 08:52 PM
sailtexas186548
Aug 24, 2015 10:11 PM
zayne0
Aug 24, 2015 07:22 PM
Thaney9
Aug 7, 2015 08:25 PM
