heater core is leaking
Old Aug 22, 2009 | 06:31 PM
micahs92's Avatar
Car: 92 RS
Engine: 305 TBI
Transmission: 4 SPD AUTO
Axle/Gears: FACTORY
fixed it
Old Aug 27, 2009 | 08:26 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: heater core is leaking
You'll probably have to remove the ignition coil to get access to the two hoses going into the firewall....Once those hoses are accessable, connect the two hoses together with some 90° pipe connectors.
Old Aug 27, 2009 | 09:30 PM
885speed's Avatar
Car: 1988 Camaro
Engine: LR4
Axle/Gears: 3.23posi/disc
Find the heater hose coming from the back of the intake, on the passenger side.
get a long enough piece of hose to run from the intake to the radiator.
Thats all I did, and it works fine.
Old Aug 27, 2009 | 10:07 PM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
Don't know about yours, but on my v6 the the in and out hose are side by side on the firewall.I would just disconnect them and clamp them onto a piece of pipe together..
Old Aug 30, 2009 | 03:52 PM
85SilverIrocZ's Avatar
I was wondering the same thing.. bout the heater core
I was thinking of... having one hose from the fire wall go right back in the other side.. and the other hose at the radiator turn back in.. as well..
kinda loop the fluid from the radiator back in.. instead of going thru the
core..... mines leaking toooo.........
FormulasOnly
Jul 23, 2018 08:47 AM
Mark_ZZ3
May 24, 2018 01:02 PM
jrdturbo
Mar 31, 2016 02:58 PM
ndndndnd
Sep 28, 2015 08:00 AM
Formula8r89
Sep 22, 2015 04:24 PM
