What size bolts are used for the air dam?
Old Aug 25, 2009 | 11:07 PM
Convoy25's Avatar
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
so i finally got one, my car never had one as long as i've had it and idk what size bolts i would put in, can anyone help?
Old Aug 26, 2009 | 03:47 PM
Convoy25's Avatar
Re: What size bolts are used for the air dam?
bump
Old Aug 27, 2009 | 03:51 PM
AZ_James's Avatar
I just got my new GM one in the mail yesterday, i can probably tell you better when I get home. As far as I remeber it looked like it had maybe a 12mm bolt with the U clip style nut on the backside which is similar to many other on the car. You should be to easily grab something from the hardware store since it will just bolt through and use the clip/nut to hold in place. I can take a pic tonight of the GM hardware I got with mine if you still need.
Kinda like this but with a larger nut.
Old Aug 27, 2009 | 04:31 PM
Convoy25's Avatar
oh ok, yeah i was lying on the ground and was feeling the upper part of the holes, and it felt like there was a nut or a lip or something
Old Aug 28, 2009 | 12:03 PM
AZ_James's Avatar
OK I got mine on this morning. The center section is held on by 6 coarse thread screws that thread right into the beam below the radiator. The ends of the center section bolt to the L and R plastic underpinning by 4 10mm bolts with the same clip nut shown above in the pic. The L and R sections of the air dam if you have them, are held on by the 7mm black screws with a smaller U clip, i think 6 in total. Heres a pic of what I got, not a good pic though.
Old Aug 28, 2009 | 03:58 PM
Convoy25's Avatar
oh ok, i just have the center section, thanks
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
wruiz
Aug 13, 2015 09:07 PM
knight72
Aug 10, 2015 09:32 PM
