4 Core Radiator Fit?
Old Aug 26, 2009 | 11:39 PM
Buckeye0001's Avatar
Car: 84 Camaro Custom
Engine: 355 Small Block Chevy
Transmission: 350 Turbo w/Street/Strip Shift kit
Axle/Gears: Stock,
I have an 84 that I put a 355 in and I want to put a 4 core radiator in it without spending an arm and a leg. I bought a radiator for a 1970 firebird from Advance and it was about two inches too long, does anyone know of a vehicle that came with a 4 core radiator that would fit a third gen?
Thank you for your time,
Matt
Old Aug 27, 2009 | 01:17 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: 4 Core Radiator Fit?
Why do you want a 4-core? I doubt anyone makes one. Try looking for aftermarket radiators, most 31x19's for chevys will fit with only a little modification, but even if you could find a 4-core, it won't be a bolt-in.
BTW, if you need a 4-core to cool a 355, something is wrong, or you are making a LOT of power with it, maybe 1000 hp?
Of possible interest: https://www.thirdgen.org/forums/cool...guys-want.html
Old Aug 27, 2009 | 08:00 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Get a 3 core off of ebay for $200. There's no way you need a 4 core.
Old Aug 28, 2009 | 09:57 PM
Axle/Gears: Stock,
Thanks a lot for your help, I will probably give that a shot
Old Aug 29, 2009 | 02:43 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Matt
All you need is a big 2 core radiator from Griffin/Becool and others
designed for our cars.
With Minor install mods.
Handle 6-700 HP.
Later
Old Aug 29, 2009 | 04:37 PM
F-Body Demon's Avatar
Oh yeah go with the Ebay one. Its $200 and its a perfect fit. Not to mention its construction is amazing for the price.
Old Sep 20, 2009 | 01:21 AM
vanillagorilla's Avatar
Car: 82 Sport Coupe Street Car
Engine: Small Block
Transmission: TH350/10"-3500
Axle/Gears: 9" / 4.56 / Spool
If you can do a little fabrication.....here's a pic of the 159.00 31x19 one from summit. It's NOT a direct fit radiator, a little trimming and fab is required, but it's about the biggest radiator that will physicallyfit between the third gen "frame rails".
Street Lethal
Apr 30, 2019 12:14 PM
Reddeath210
Oct 6, 2015 08:20 AM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
