Upper radiator support
Old Sep 15, 2009 | 07:54 PM
steNcho's Avatar
Car: 1989 Chevrolet Camaro IROC-Z
Engine: 355 SBC
Transmission: TH350 with 3500 stall
Axle/Gears: GM 12-bolt with 4.10 gears
Hi guys, I recently switched from a clutch fan to my new flex-a-lite 180 electric fan in my 1982 Z28E with a 355. I cant use the old fan shroud anymore offcourse. Anyone have a shroud that only holds the radiator and not the fan. Or anyone have any ideas to fabricate a simple upper support bracket for the radiator. Want it to look nice but nothing too fancy. Thanks!
Old Sep 15, 2009 | 09:14 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: Upper radiator support
You should be able to fabricate one out of aluminum fairly easily with household tools.
Otherwise, get a tpi one from an electric fan.
Old Sep 20, 2009 | 01:03 AM
vanillagorilla's Avatar
Car: 82 Sport Coupe Street Car
Engine: Small Block
Transmission: TH350/10"-3500
Axle/Gears: 9" / 4.56 / Spool
Here's the one i built for my new radiator. You can't see it in the pic, but there's a length of 3/4" heater hose that's been filled with silicone (to make it less likely to flatten out over time) under that peice of "c" channel that hits the radiator top instead of the metal of the c channel. It works great.
Old Sep 27, 2009 | 10:25 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
that pic above is sweet, if i was needing a shroud, id hit up home depot and get some sheet metal cheap. and just fab it, then race or take hot ladies for a ride. wink
Old Sep 27, 2009 | 11:09 PM
Engine: Small Block
Thanks man....i have a big electric fan going behind the rad. The whole car is in the process of being built,(re-built...we've had it since 85...it's had a few encarnations..lol) so everything's getting done at once...that's why so much stuff is just laying around in the pic..LOL.
Old Sep 28, 2009 | 12:14 AM
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
i just took the stock electric single fan support and trimmed the back with my dremel. came out great, still does the job. you can get them on ebay fairly cheap.
Old Sep 28, 2009 | 11:33 PM
this dude, like unbolted the cat and ran straight open exhaust, shattered his rear hatch. it was awesome
sheachopper
Jul 31, 2019 11:27 AM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
