dual fan amp draw
Old Sep 16, 2009 | 03:25 PM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
dual fan amp draw
I have twin electric stock fans in my 87 gta. I wired them together, on a 30a circuit with a relay for ignition on operation. I drove the car for a half hour or so and the fuse blew. What is the amperage draw for the two fans together??? I wired in a fan switch to the manifold on the ground, so that the fans don't run constantly, i'm thinking that will help, but i am still wondering why 2 fans would blow 30a circuit. Hoping withthe fan switch that it won't happen again, but just want to make sure it's safe.
Old Sep 16, 2009 | 03:56 PM
racethesunlive's Avatar
Car: '92 Camaro
Re: dual fan amp draw
I could be wrong but i thought it was 20A per fan...
Old Sep 16, 2009 | 06:33 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
I tested a set of those fans once and found each fan
motor pulls 7.5A once up to speed,getting up to speed
(first couple seconds)each motor pulled over 20A,so if
you use a seperate fuse of 20-30 for each motor setup
should work fine.
Old Nov 10, 2009 | 10:25 AM
Car: 1987 GTA
its been cold out, but it seems to be working on the switch, doesnt blow fuses now
Bubbajones_ya
Jul 6, 2024 08:32 PM
Kylej68
Exterior Parts Wanted
Sep 28, 2015 10:00 AM
ivan1137
Sep 23, 2015 09:08 AM
gta892000
Sep 16, 2015 12:37 AM
scotrans am
Sep 5, 2015 04:26 AM
