Cooling Fan Power Supply??
I have a 1992 Camaro RS that i recently did a swap to a 355. A few days ago, i had to have the motor pulled and put back in, in order to drill out two broken header bolts. Ever since i picked it up, it has been overheating at times. It is fairly cold out, and it seems that as long as i keep moving i'm alright, but when i stop for a short period of time, it overheats. I am considering the possibility that the fan was not hooked back up, although i havn't gotten a chance to take a look at it because its dark out. There is an extra plug up by the batter/radiator that i do not remember before. I was just wondering how the Fan is supplied with power, and where the plug for it goes, so i can see if this is it. Thanks!
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Cooling Fan Power Supply??
There is a fan switch in the pass head between #6 and #8 cylinders - this senses the coolant temp and turns on the fan.
There is a fan relay deiver side fireqwall between the brake booster and the fender - there are two relays there - the one with the large black with red stripe wire is the fan relay.
There should be a fusible link that runs to the fan relay - the fusible links are beside the battery on the radiator side.
There should be a wire loom with a connector on it that plugs into the fan motor.
One test is to turn the car to on, and turn on the A/C - if the fan is running with the A/C on, then you know the fan works, and that it's wired properly, and that the relay is good - which means your fan switch is bad.
I myself like the seperate fan controllers with the probe that runs between the fins on the radiator - I';ve had one form Flex-a-lite now for 3 years and had no problems. It's fully adjustable on and off temps, easy to install, has provisions for manual on and manual off switches, connects into the A/C system for extra cooling when A/C is on, and works every time - was about $80 at summit (cheaper than the Hypertech fan switch).
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
That's probably it. Should be a two wire, heavy guage connector that plugs into the bottom rear of the fan motor.
Car: 1986 Chevrolet Camaro Berlinetta
Engine: 305ci.
Transmission: auto
Axle/Gears: stock.
Ya know i was about to ask a question myself about this. Until reading this forum. Thanks It helped me on which wire wen to the relay and where to find it LOL im loveing this site hehe.
sailtexas186548
Aug 24, 2015 10:11 PM
