gurgling in overflow, possible that this the source of air?
Old Nov 10, 2009 | 07:17 PM
street_carnage's Avatar
Car: 89 GTA
Engine: 5.7L
after running the car and it not overheating at all, the overflow sometime bubbles. i know its not a head/gasket as i have no other symptoms of this. now, i was going to do the basic things first, burp the system, install new thermo, rad cap etc. but i do have a leaking heater core. well, its not leaking in the pass. area yet, but i do smell coolant when i slide the heater on. so if the heater core WAS leaking, is that a big enough source of air to cause the overflow tank to bubble?
Old Nov 10, 2009 | 07:21 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
Re: gurgling in overflow, possible that this the source of air?
might as well replace the heater core while u have the coolant drained out for the thermo install. refill /burp as needed.
the only time ive seen a over flow tank bubbleing is when my bird over heated. coolant might be to low also.
Old Nov 10, 2009 | 07:57 PM
vette gator's Avatar
Car: 85 Z28
Even though you don't seem to have any head gasket symptoms, it would be worth using the tester kit with the liquid that turns from blue to yellow if you have exhaust gases in the coolant. NAPA sells the kit; other places might rent it (but I'm not sure about that).
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
