weird cooling problems!!!
Old Nov 22, 2009 | 02:30 PM
jnmaro's Avatar
Car: 92 camero rs
Engine: 305 tbi searching for 5.3
Transmission: t5 wanting a t56
Axle/Gears: b/w 9bolt
Ok So My 92 camero 305 tbi started over heating so I started with the most commin stuff. The termastat (180 degree) gave it a good Flush(super coolant and a 60/40 more water) new emergancy release cap. Then moved on; found a small leak in the radaitor so I replaced that but was still overheating in traffic. So I put a larger aftermarket electric fan in. I have it set up as a puller fan and Wired it into the exsiting wiring. fan seemed to be moving good air but still having problems in slow traffic. I then continued to replace the temp sensor and the sender on passenger side. Now The gage says I'm over heating the fans doesn't seem to be coming on. But when It says I'm over heating I have no boiling and the hood stiill feels cool? Could the gage be wrong? Didn't want to keep driving when its says i'm supper hot to test my theory; Is there a way to test it the gage with a voltage meter?
Ghettobird52
Jul 5, 2024 11:18 PM
chazman
Aug 28, 2018 03:25 PM
Cleotiz
Jan 6, 2018 08:56 PM
CORV3TT3
Aug 23, 2015 11:26 AM
sreZ28
Aug 14, 2015 07:48 PM
