406 w/ stock radiator?
Old Dec 20, 2009 | 09:19 PM
GICATA's Avatar
Car: '83 WS6 T/A 65,000 miles
Engine: 5.0L vin H stock, 406SBC right now
Axle/Gears: Corp. 3.73
I am planning to put my 406 (chevy) in my TA, using the stock radiator. This engine stayed cool in my truck with the stock 3 row and A/C even in the hot, humid summers here in Cesspool except in the occasional traffic jam @ 95 degrees. I am not really willing to install an expensive aluminum radiator that reqiures fabrication to install.
The engine isn't really a monster motor, it has a 270 Comp Magnum cam, stock Sportsman heads with 1.6 rockers, +.030 bore (I don't know the wall thickness as it wasn't soniced when rebuilt) 5.7 rods, about 9.75 to 1 static compression and Edelbrock RPM with a Holley. Like I said, nothing too special.
I really plan to run the car mostly in the fall/winter as the summers here are torture with glass T-tops. That alone may pass the need for any further conversation, but I would like to hear from anyone else who has had some sort of experience with this set up.
Btw...yes I searched and I am on the board numerous times a week and have yet to really find info directly related to my proposal.
Thanks.
Old Dec 20, 2009 | 10:09 PM
calroc's Avatar
Re: 406 w/ stock radiator?
I'm sure you're going to get a lot of opinions & personal experiences, pro's & cons. I will tell you mine. I have the original radiator in my '85. Originally a 305 TPI, it has been a 383 for the past 16 years, AFR 195's, cam & 1.6:1's, 10:1, SupeRam EFI. I have changed the stat to a 160 & programmed the single fan to come on @ 160. I have never had an overheating episode, ever. I realize your carbed system may, or may not make a difference.
Old Dec 21, 2009 | 09:29 AM
GICATA's Avatar
Thanks for the quick post, I want the personal stories!
Old Dec 21, 2009 | 09:51 AM
jm84z28's Avatar
Car: 1984 Z28 camaro
Engine: 388 ci stroker
Axle/Gears: 3:73
yeah same here i have a 388 stroker and have no problems with the stock radiator.mine motor was bored.60 over so i was a liittle worried but i pulled my condenser and put a restrictor plate in the theromstat house and it runs at 170 degrees. u should be fine
HotRod
Aftermarket Product Review
Jan 15, 2002 05:57 PM
GOLD85
Nov 12, 2001 10:50 PM
Duke901
Oct 29, 2001 04:44 PM
Scott_92RS
May 13, 2001 09:20 AM
89ragtop
Mar 7, 2001 06:32 AM
