What type of crank do i have
Old Nov 12, 2001 | 09:49 PM
GOLD85's Avatar
i have a stock 400 crank. is it cast or nodular. if it is nodular is there any beafits over cast
when the green flag drops the bull$hit stops
Gold 85 Camaro with no motor, pulled the 2.8 to make way for a 350 wich was pulled this summer because a 406 will replace it. The 406 sports a stock bottom end with ARP bolt holding it togeter, flat top hyper pistons. Comp 282 solid cam(.528 lift with 1.6 rockers) Savin up for my Sportsmen 2 heads right now. still Have the perf RPM and 650 DP i used on the 350. Headers and 3inch exhust. Shooten for mid to low 12s next summer
Old Nov 12, 2001 | 09:53 PM
89BlwnRs's Avatar
I'm not 100% on this, but to my knowledge, nodular IS cast.
Jason
Old Nov 12, 2001 | 10:30 PM
SoCo80p's Avatar
Nodular is cast correct, but a much stronger casting, on 66-73 engines they used nodular iron cranks that were quite a bit stronger, you can tell a nodular crank as on the crank itself on the first counterweight will be a big N cast into it.
Old Nov 12, 2001 | 10:34 PM
GOLD85's Avatar
cool man thanks
Old Nov 12, 2001 | 10:50 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
All stock 400 cranks are the same casting #... 509 if memory serves correctly... all are nodular cast.
ICON Motorsports
MrPackstin
Oct 25, 2017 08:09 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
skinny z
Oct 5, 2015 06:23 PM
Briandrex
Oct 5, 2015 06:20 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
