coolant under car near firewall and driver floor
Old Dec 24, 2009 | 05:37 PM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
i replaced the heater core 2 yrs ago. new water pump. rad done 2 years ago. just suddenly saw coolant on the ground this morning at work like one of the heater hoses to the core. dont know for sure yet. when i got home from work my rubber floormat was wet. looked and it was coolant. on the driver side. if the hoses outside are bad then could it blow coolant in and run to the driver side. never heard of that but theory sometimes helps. i know that heater cores usually put it in the pass side. i dont think that it would be bad yet though. ideas or any help would be great. couldnt find anything searching.
Old Dec 27, 2009 | 02:14 PM
Re: coolant under car near firewall and driver floor
apparently coolant is now also dipping on the pass side. bought a heater core will replace and see if it fixes problem.
Old Dec 27, 2009 | 03:35 PM
BlackMamba's Avatar
Car: 84 Camaro Z28
Engine: 355 Carb
I am in the same position as you. Everytime I wash my car or use my car, I see liquid under the pass carpet and have to clean it with the vacumm before it gets worst. I even replace the core, hoses and still show signs of liquid of some sort. When I looked under my car, I saw a some liquid coming from a little crack in the chassis. I was thinking of covering it up but never had the chance to it
Old Dec 31, 2009 | 05:14 PM
pulled out heater core. ended up being a loose hose. installed new core anyway since it was out. now i have a spare for my wifes car. no more leaky.
Old Jan 10, 2010 | 08:54 PM
morepowerjoe's Avatar
Car: 86 Camaro
How hard is it to replace that heater core? Whats involved? Thanks.
Old Jan 10, 2010 | 09:08 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Here's a start:
https://www.thirdgen.org/forums/tech...e-82-86-a.html
JamesC
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
TheExaminer
Aug 26, 2015 04:59 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
