Lube your cables for colder a/c
Old Jan 11, 2010 | 06:15 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Just thought I would share a simple discovery. Replaced my heater core today and noticed the vent door that moves with the "hot,cold" lever wasn't closing all the way when the lever was pushed all the way to "cold", meaning some hot air from the heater core would be allowed to pass through the door and through the vents into the car, even though the lever was all the way to "cold". So, if I was running the a/c it would have some hot air mixed with it. I'm certain this is why I could never get my last Camaro to blow cold enough a/c.
I sprayed some silicone lube all over the cable that moves the little vent door open/closed and now the door closes completely with ease and with no adjustment of the lever itself. You should be able to access this point on the cable by removing the passenger under-dash panel, without removing any other dash parts.
Attached Thumbnails Lube your cables for colder a/c-hpim1388email.jpg   Lube your cables for colder a/c-hpim1386email.jpg
Old Jan 11, 2010 | 06:50 PM
85 ZXX's Avatar
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
Re: Lube your cables for colder a/c
Nice job of pointing out the tips and tricks!!!
jrdturbo
Mar 31, 2016 02:58 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
2012sergen11
Oct 13, 2015 07:38 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
