Fan 86 berli
Old Jan 11, 2010 | 11:43 PM
U.S.Marine09's Avatar
Car: 1986 Berlinetta, 1988 Iroc-Z
Engine: 305 carb, 305 TPI
Transmission: 700r4, 700r4
Axle/Gears: stock
Fan 86 berli
so the other day my radiator fan stopped coming on at all and my car started to over heat i want to fix it and i was wondering if my cars (305 carb) fan is controlled by a switch or the ecm so i know what to change
Old Jan 13, 2010 | 01:53 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Fan-Tastik
The fan is controlled by the ECM.
Check the FAN fuse under the dash.
Next check the fan relay located in the engine compartment on the firewall, near the brake booster.
It’s the one on the left.
( Driver’s side for newbies. )
You can switch relays for testing.
You can apply 12 volts directly to the fan to see if it works.
The ECM turns on the fan about 220°.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime, and the nitwits that need headlights for a little rain
Old Jan 13, 2010 | 10:01 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: Fan-Tastik
G & H engine codes (LG4, L69), electric fan is controlled by the fan switch, 238°F on temp, passenger head.
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
