Just another project...
Car: 87 Z-28, 89 GTA, 79 WS-6,
Engine: 87- 305 TPI, 335 stroker, 403 Olds.
Transmission: 700r4,700r4, and th400
Axle/Gears: mostly stock
Got a question. My temp guage on my 87 Z has given up. It shows a constant less-than-zero setting. When I bought the car, the origional owne had set up one fan to run constantly, now, niether one comes on, and I'm unsure if the two are related or has a relay gone bad?
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
Re: Just another project...
umm the censor on the block/head may have came off if some one was in the engine bay. happened almost everytime i changed theoil in my 84 camaro. as for the fan thats suppose to come on at all times as the po inteaded...its been hot wire and unless its been undone im putting money on the motor burned out. as for the 2nd fan? im guessing burned motor or bad relay.
Car: 86 IROC-Z28
Engine: LB9
Sounds like a good idea, but I'll have to wait till it thaws out. Got 4 inches of snow and an inch of ice in the yard, and too cold to spin wrenchs under the carport. Gotta love this global warming...
Where exactly is the fan relay located, on the firewall or down by the radiator?
ambainb
Apr 25, 2016 09:21 PM
