Goodyeard radiator hose collapsing
Old Feb 6, 2010 | 06:30 PM
AC's Avatar
AC
Car: Used to drive a camaro
So I figured I'd need an internal spring for the lower radiator hose but when I bought the goodyear blue hose kit I figured, hey it's goodyear it has to be decent. Well the lower doesn't have a spring and when it was idling I blipped the throttle and didn't that damn thing almost completely flatten. I'm using a Miloden water pump if that makes the situation any worse. Where is a good place to get a spring / coil so I can put it in the lower radiator hose?
Old Feb 8, 2010 | 02:11 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
The Hose Knows
OK you blipped the throttle and it collapsed, but did it stay collapsed?
Does it collapse at steady idle, or high RPM?
If not, it’s OK.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog or “running” lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime and the nitwits that need headlights for a little rain
Old Feb 8, 2010 | 04:10 PM
AC's Avatar
AC
Re: Goodyeard radiator hose collapsing
Id did not stay collapsed, i.e. when I let the throttle bracket go, the hose went back to normal. The blip of the throttle put it I'd guess 3000+ rpms.
Old Feb 9, 2010 | 02:55 AM
oil pan 4's Avatar
Car: 89 Firebird
Does your cooling system pressurize when warm?
Old Feb 9, 2010 | 09:48 AM
NINÅ's Avatar
Transmission: 765R4
The Hose Knows
Due to the fact it collapses only during the blips there’s no problem.
However if you still don’t want it you can get a spring from a junk yard.
Few or no manufacturers are putting springs in those hoses now.
Happy Racing!
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
