HELP ME PLEASE! MY FAN WONT WORK!
Old Feb 27, 2010 | 01:09 PM
scottydodo's Avatar
I HAVE A 91 RS 3.1 I HAVE CHANGED EVERYTHING IN THIS RIDE. FAN CENCER, FAN RELAY, ECM, TEMP CENCER, I HAVE CHECKED ALL THE WIRES. I CANT FIGURE IT OUT ANY IDEAS?
Old Feb 27, 2010 | 01:26 PM
chads89ta's Avatar
Car: red 89 t-top ta
Engine: 305 tpi
Transmission: t-5
Axle/Gears: 9 bolt soon
Re: HELP ME PLEASE! MY FAN WONT WORK!
have you checked the connector at the relay,check for power going into relay and power coming out, the sensor on the block is atrigger to ground the relay. so you will have power a ground and a trigger ground into the relay the
Old Feb 27, 2010 | 07:20 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Have you tested the actual fan to see if it works?
Old Feb 27, 2010 | 07:29 PM
Blind Driver's Avatar
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
Why are you yelling?
It's spelled "sensor"
Old Feb 28, 2010 | 12:27 AM
sparkplug619's Avatar
Car: 1990 RS Camaro
Engine: 305 TBI
Transmission: T-5 stick
check for power yo.
get a circuit tester for 3 bucks at autozone and start sticking it around
an easy thing to do first is to check the fan plug itself. if it get power then more then likely its the fan. if the fan is not getting power, check what everyone above me mentioned.
Old Feb 28, 2010 | 09:53 AM
bcmag's Avatar
i think camaro newbie got this, check fan motor itself
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
TA8487
Aug 16, 2015 12:21 PM
Leggman1
Aug 6, 2015 04:15 AM
