Car runs cool while driving but not when stopped?
Old Mar 20, 2010 | 02:50 PM
jbarboza19's Avatar
Car: 86 Iroc
Axle/Gears: GU5 323
86 Iroc, 305 tpi, car runs around 160-170 while driving but heats up to around 230-240 ( when fans kicks on) when just sitting. Normal? Any direction would help before I start replacing everything. Was going to start with a lower fan switch and lower thermo? Thanks in advance.
Old Mar 20, 2010 | 03:16 PM
campin1983's Avatar
Car: 1984 Camaro 'Vert
Re: Car runs cool while driving but not when stopped?
Fan would be my first suspect, I'd also do a coolant flush before all else and see how much/if that helps.
Does the cooling fan actually turn on at any point? My old 'bird wouldn't turn its fan on unless you turned on the AC. The switch was toasted.
Old Mar 20, 2010 | 07:27 PM
JT's Avatar
JT
Community Administrator
The primary fan doesn't turn on until around 222F. This is stock for emission reasons. Given the different sensor for the gauge and sensor, and that factory gauges are not accurate and hard to tell between 222F and 230F, it sounds like your case is normal.
The car runs cooler while driving because outside air is flowing through the radiator.
Do you have one single fan or dual fans?
Old Mar 21, 2010 | 08:35 AM
jbarboza19's Avatar
Car: 86 Iroc
Axle/Gears: GU5 323
Yes, my fan turns on around 220-230 cools motor down to 180-190. Motor stays around 160 while driving on highway. And I have a single fan. I'm going to do a complete system flush. Possibly a new radiator ( being that I'm noticing a small leak ) and a thermo. Thanks guys for ur help.
Old Mar 22, 2010 | 11:01 AM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
They sell an aftermarket switch that turns them on at a lower temperature. Unless yours is pcm controlled which I think that only the 2nd fan in a dual fan setup was im not sure though. I have dual fans, my primary fan is wired on all the time and the second fan is on a toggle switch in case things ever get too hot. Flush might help but i think the problem is your fan. I had an rs with a single fan and I just wired it on all the time, its not as good to have it on all the time but it works.
Ghettobird52
Jul 5, 2024 11:18 PM
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
