Where do you think coolant is going?
Old Apr 1, 2010 | 08:41 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
There is a leak somewhere, because when looking in the radiator with car running, it looks like rapids. Coolant is swishing around. Now there is no white smoke and nothing in the oil. No puddles on the ground. I believe it is leaking through the rad or water pump because the level dropped some after it was filled and sat for a little bit without starting.
Old Apr 1, 2010 | 09:19 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Where do you think coolant is going?
the coolant is likely evaporating before it can drip to the ground. the best way to find the leak is with a pressure tester with the engine cold. or look for coolant residue on the engine.
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
