Spring in lower radiator hose.
Old Apr 24, 2010 | 06:29 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
I will be replacing my hoses soon. I am wondering if I have to put the spring that is in the factory lower rad hose into the new hose I purchased.
Old Apr 24, 2010 | 06:42 PM
HankL69's Avatar
Car: 85 IROC / 69 Firebird convertible
Engine: 5.0 / 350
Transmission: t-5 / WC t-5
Axle/Gears: 3.27 / 3.08
Re: Spring in lower radiator hose.
The spring is there to keep the hose from colapsing when the car cools down. If the new hose doesn't have one then you don't need one.
Old Apr 24, 2010 | 10:36 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Originally Posted by HankL69
The spring is there to keep the hose from colapsing when the car cools down..
Usually, they (the spring) are in there to keep the hose from collapsing when the hose gets hot and soft and the pump is sucking water up through the hose (to the block). During high rpm and heat, the draw (suction) can cause the hose to collapse.
Crappier made (the low buck, $1.05, ones) replacement hoses will generally have them (springs) over more costly, well made (thicker, better internally lined) ones.
Use it if it fits/you want to, it won't hurt anything.
Old Apr 25, 2010 | 01:38 AM
y84pauloflondon's Avatar
Car: 87 T-Top GTA
w/Deadbird!!!
my86bird
Oct 23, 2015 12:20 PM
86CamaroDan
Sep 29, 2015 10:08 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
Night rider327
Sep 2, 2015 04:18 AM
