Electric fan and ECM question
Old Apr 27, 2010 | 01:00 PM
Mikes86transam's Avatar
Car: 86 Trans AM LG4 5spd
Is the electric fan on my 86 Trans Am (LG4) computer controlled? I'm removing the ECM and going with a Holley carb and MSD ignition. If it is controlled by the ECM how can I keep my stock electric fan working without it?
Old Apr 27, 2010 | 02:35 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: Electric fan and ECM question
Someone can correct me if I am wrong, but I don't 'believe' that the fan is ecm controlled.
Old Apr 27, 2010 | 02:59 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
I think it may be. If it is, the relay is grounded by the computer, which activates the fan. I believe this is the dark green wire which can be wired directly to a switch anywhere in the car. Otherwise, the fan is grounded through the temp switch in the side of the head which grounds the circuit at a predetermined degree. This is also a dark green wire which can be gounded through a manual switch as well.
Old Apr 27, 2010 | 03:09 PM
I'm confused. If the fan is turned off and on by a temp switch mounted in the head then what role does the ECM play in the operation of the fan?
Old Apr 27, 2010 | 03:18 PM
1981LT1's Avatar
Engine: LT1; LT1
I am not 100% it is not controlled by the computer. I was giving you both scenarios
Old Apr 27, 2010 | 09:16 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Go to Technical articles section on this site, then down to electrical, then click on the fan system you have and it will all be revealed. Have fun
Old Apr 28, 2010 | 06:53 PM
Thanks! Got the info I neededl Looks like the single fan setups are not computer controlled.
MustangBeater20
Oct 29, 2022 09:20 PM
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
