Aluminum Radiator leaks...help
Old Apr 29, 2010 | 07:56 PM
Mike1's Avatar
My $$$ radiator started leaking. Can't tell exactly where so a mechanic friend let me borrow his pressure tester and told me that when I put pressure to it I should see a stream of water coming out, mark that spot and he will get it welded. Well when I pressurize it no water comes out but I here air leak. It has been dripping while the car is parked and hasn't been driven in a week, that's when I noticed the leak. I can't find the spot...what the crap am I supposed to do now. Whats worse is I was searching the boards and read an old thread about someone having electrolosis and eating several radiators now I am getting really worried. Can I use some of that stop leak stuff or am I out all that money for this radiator?
Mike
Old Apr 29, 2010 | 08:42 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: Aluminum Radiator leaks...help
it you cant sleep over it..take it out..take it to a Radiator shop.
they will test it under water.. for free.. and you can pay them to Fix it.
$40?
yes you can use some stop leak to see if that will work for you.
but remember: it a temp thing..
just before you take it to a shop..buy some screw in freez plugs($4) to seal up the Hose Holes. pump it up to 14psi and see if you can see the hole/s your self
Old Apr 29, 2010 | 09:00 PM
y84pauloflondon's Avatar
Car: 87 T-Top GTA
Mike
This might suggest that the leak is up high on your rad since your hearing air coming hissing out. I would top off the rad and try the test again. I would also take the time to make sure that the hoses are nice and tight.
Old Apr 29, 2010 | 09:16 PM
Mike1's Avatar
I had it out but put it back in to try to pressure test it. I got my multimeter ou to test for electrolosys. Never checked for this before but that may be the issue. I gotta figure out how to fix that. I don't have any knowledge on this.
Old May 1, 2010 | 06:37 AM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Does your friend have the dye to put in the rad?
Basically, it gets poured in, the car is driven // run til it reaches norm temp, then you put on certain yellow glasses, use a special ( uv or infrared?? ) light, and where ever there is even a trace of leak, it will have a distinct color.
There is a thing that can be attached to the rad cap that attracts the stuff that causes eletralysis (sp?) so aluminum doesn't erode. Local auto store may have it, or Summit & Jegs.
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
jrdturbo
Mar 31, 2016 02:58 PM
lanceflame44
Sep 25, 2015 12:28 PM
