how bad is it too overheat fresh motor
Old May 4, 2010 | 11:22 PM
luke89's Avatar
Car: 96 jeep cherokee, 89 camaro
Engine: 355
Transmission: t5
Axle/Gears: eaton locker/3:73 gears
hi. ive been having problems keeping my engine cool. its overheated maybe 5 or 6 times like over 260. once i drove it a few miles hot on accident. did i ruin my engine. i just rebuilt it bored 40 over. it still seems to run good but im really worried all my hard work and money was a waste. i got the problem fixede now i just wanna know peoples opinions on if i damaged anything. thanks.
Old May 4, 2010 | 11:32 PM
zachkuby87's Avatar
Car: 1985 iroc z
Engine: 350 .30 over
Transmission: t-5
Axle/Gears: told aftermarket moser 3.73 posi?
Re: how bad is it too overheat fresh motor
same thing happened to me last summer fresh motor wasnt paying any attention to the temp gauge till the car started running like **** i didnt really drive it much after that for the summer and this winter i put in a bigger radiator and electric fans no more cooling issues but after maybe 500 miles all together since the motor was done i only drove it a week or two this year and i have a bad lifter i dont know if its related to it overheating but... now i refuse to drive it until i have enough $$$$
to fix it
Old May 4, 2010 | 11:40 PM
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
might of hurt, might not of. its to late for that now so lets try fixing the problem. do you have a thermostat? do you have electric fans? do they work? is your radiator junk? is somethign blocking air flow to your radiator?
Old May 5, 2010 | 12:21 AM
The_rabbit1's Avatar
Car: '87 Iroc
Engine: 350 .060 over
Axle/Gears: 3.70 9bolt
Steel heads? probly not, steel heads would almost survive the holocaust without warping. Aluminum heads on the other hand...
Old May 5, 2010 | 12:27 PM
luke89's Avatar
Engine: 355
Transmission: t5
yeah steal heads and the problem was the fan was spinning way to slow. its fixed now.
Old May 5, 2010 | 10:41 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
They would be iron heads, not steel. But if you didnt burn up a head gasket or anything like that from overheating, its fine. Overheating and engine wont ALWAYS screw something up.
Old May 6, 2010 | 04:52 AM
MotorMouth's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
That is why your radiator cap vents off the excess pressure. I have seen mine peg about 6 times until I found the problem was the fuse link going to the fan. The engine is still running and going strong. It has almost 190,000 miles on it now.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
lakeffect2
Aug 23, 2015 08:44 AM
Bradsaundry
Aug 12, 2015 12:34 AM
