Another fan question.
Old May 8, 2010 | 02:44 AM
wht96's Avatar
I Just finished my lt1 swap and im finishing up the last details. I have the a/c disconnected is there anyway to make the fan run normally, instead of always on with the a/c completely disconnected? I don't want to use a toggle switch and i really dont want the fan to run constantly. Any help would be awsome
Old May 8, 2010 | 02:49 AM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: Another fan question.
well if you just finished your LT1 conversion why didn't you hook up your fan through the ECM? if that's not an option for whatever reason... then check to see if you have an area where you can install a temperature switch...
you would wire your fan with a relay to a 12v ign source, this way your fan won't stay on after you've shut the engine off... your fan will now cycle on and off ...
Old May 8, 2010 | 09:16 AM
wht96's Avatar
I dont think you completely understood what i was saying. My fan does't come on Unless the engine is running. Not just if the key is in the "On" position but the motor physically running and the fan will be on. What i think is the problem is, I have the a/c dissconnected, so the fans will stay on because the pcm is telling them to because the a/c isn't connected. What I'm asking is does anyone know how to "trick" the pcm into think the a/c is fine, so that my fan will act normally
Old May 8, 2010 | 10:03 AM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
See if jumping the old ac pressure switch wires together stop the fans.
Old May 8, 2010 | 01:25 PM
wht96's Avatar
I'll try that and let you know.
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
