OEM Radiator # for 350???
Old May 10, 2010 | 04:28 PM
Chuck's Avatar
I have a 350 in my '88 IROC-Z, however originally
engine was 305, so VIN number not helping me
find the correct OEM radiator. Can anyone help me?
Old May 11, 2010 | 10:04 AM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Re: OEM Radiator # for 350???
I dont know the oem number but I think you would have good results with one from autozone. I bought one about five years ago and have been happy with it. A competent chevy dealer should be able to figure it out without a vin.
Old May 12, 2010 | 01:27 AM
Blown84Bird's Avatar
Car: 84 firebird, 85 transam
Engine: 350 SBC Or 7.07 Tonys,305stock
Transmission: Big Ugly, 700r4
Axle/Gears: 4th gen rear disk 3.42 lsd,9 bolt
Yeah just go to AZ and get Rad w/ HD cooling
Old May 12, 2010 | 04:03 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
When I bought my Camaro in 1984 it would overheat every now and then so I checked Chev service bulletins and found this bulletin.
Bulletin # = 84-154
Section 6B(XIII)
Date June 1994
New radiator assembly #3047198
New lower air deflector #14079836
I had the radiator and deflector installed under warrenty. The car was ok after that. The radiator (three row) and deflector looked the same as the takeoff parts but must of been made of differant materials. I have since then installed a 355 and it will only overheat when it is 90*F and using the A/C stuck in traffic. If I turn off the A/C it cools down pretty quick. I run a 160* stat with (4) 3/16" holes drilled in the stat. Only good for summer.
Auggie
Old May 12, 2010 | 09:34 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
current, 52497687 (gmpartsdirect or, newgmparts)
There was only one radiator for the v8.
Only the 2.8 v6 had a different radiator from any of the other engines in these cars (if I recall correctly).
1992 Trans Am
May 10, 2023 07:19 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Eric-86sc
Aug 24, 2015 09:01 PM
theshackle
Aug 22, 2015 06:52 PM
