No need for engine oil cooler, switched to power steering cooler?
Old May 17, 2010 | 09:00 AM
Zantasmo's Avatar
Car: '87 Iroc-Z, '91 Trans Am Vert
Engine: 5.7 LS1, 5.3 LS
Transmission: T56, T56
Axle/Gears: 4.11, 3.27
I have a '87 Iroc-Z that was a 5.7 TPI with TH700.
Car is undergoing a LS1+T56 swap. As you know, the original radiator has the engine oil cooler in it.
I was wondering if there is any reasons why I couldn't use the original engine oil cooler for the power steering?
Car is going to see some serious track days.
Old May 19, 2010 | 12:38 AM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: No need for engine oil cooler, switched to power steering cooler?
The cooler in the radiator is for the transmission fluid, not engine oil. It is designed not only to cool your transmission fluid, but to bring it UP to the proper operating temperature via the coolant in the radiator. Since your swapping a T56, obviously you have no use for a transmission cooler, and you could "hook up" the power steering lines to that cooler, probably with no ill effects, but I dont see what you would gain from it.
Old May 19, 2010 | 09:21 AM
Zantasmo's Avatar
Okay... but isn't the engine oil cooler also in the radiator?
Old May 19, 2010 | 09:24 AM
Twin_Turbo's Avatar
No, the KC4 cooler routes coolant through the sandwich adapter on the filter pad. There's a heat exchanger inside.
Bad idea to use the rad for a p.st. cooler.
I've had a quality (mocal) cooler burst from a mishap w/ a KRC power steering setup. For some reason yet still unkown I had a huge pressure spike through the cooler (which is on the low pressure side of the system, in the return line to the reservoir) and the cooler developed a leak. Last thing you want is for that to happen inside the radiator.
Old Mar 10, 2019 | 07:48 PM
eshaw's Avatar
Car: 16' Silverado
Engine: 5.3
I think I'd run some CLR through it and see if it looks OK on the inside. As long as the inside doesn't look compromised in any way, like thin spots, etc. I'd roll with it.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Navy8125
Aug 21, 2015 09:32 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
