Cooling Fan Won't Turn On...
Old Aug 6, 2019 | 09:57 PM
  #51
Evilokc's Avatar
Car: 1991 base firebird
Engine: tbi 305
Re: Cooling Fan Won't Turn On...
Originally Posted by allenrep2000
The brown wire from the terminal block to the white inline fuse supplies power for the cooling fan. I found it completely disintegrated
how do you check this type of fuse? I thought it was a plastic cover over a glass cylinder type fuse but I don't see how it opens.
Old Aug 6, 2019 | 11:02 PM
  #52
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
It doesn't open. You either have continuity from one end to the other or you don't. If not it's no good
Old Sep 7, 2020 | 01:13 PM
  #53
sb4's Avatar
sb4
Hi guys!
There is a problem with my 91 Trans AM, about several months can't resolve it.
So I have TPI on my 305ci LB9 engine with two fans, but 2nd doesn't starts.
When temperature rize up to 240F/115C, only 1-st fan (black/red wire) starting.
Also it's starts when I connect with paper clip A+B ports at diagnostic can.
2nd fan I can start only when I connect pigtail connector to ground or shortcut relay (black/pink wire).
all parts are new, caps, sender, sensor, switch, thermostat, rediator, waterpump and hoses.
what did I miss?
gauge STANDARD MOTOR PRODUCTS TS76
switch ACDELCO D1852B
sensor STANDARD MOTOR PRODUCTS TX3
thermo STANT 13356
Old Sep 22, 2021 | 12:16 PM
  #54
Jlabbe73's Avatar
I have a 1985 camaro z28 and I cannot find my cooling fan switch on the passengers side I don't even see the wire I did find one sensor on the drivers side maybe the one on the passenger side broke and the wire broke off where does the wire connect to
Old Sep 22, 2021 | 09:20 PM
  #55
Evilokc's Avatar
Engine: tbi 305
when you are under the car find the dip stick on the passenger side. the temp sensor os up and to the rear of where the dip stick mounts. should have a plug with a single wire on it.
Old Sep 22, 2021 | 09:28 PM
  #56
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
I've heard 85-86 was weird and didn't have one. Is there a plug between #6 and #8 cylinders?
Old Sep 23, 2021 | 06:42 AM
  #57
Jlabbe73's Avatar
There's no plug between #6 and #8 just one between #1 and #3
Old Sep 23, 2021 | 06:43 AM
  #58
Jlabbe73's Avatar
There's no wire there I look just one on the drivers side between 1 and 3
Old Sep 23, 2021 | 09:20 PM
  #59
85-86 was weird
No. Same as any other SBC.
No. There's a plug there. Your 2 heads are IDENTICAL IN EVERY WAY. Imagine taking them and setting then side by side, off the engine. Line em up so that you're looking at the exh port side of each. There will be a hole between the left-most spark plug hole and the next one. On the head you then put on the driver's side, it will be between the #1 & #3 spark plugs. The same hole in the other head will be between the #6 & #8 spark plug holes. One side has had the temp gauge (or idiot light) sending unit in it, since 1955; the other has always had a pipe plug, until around 83, when electric fans were introduced.
No. Don't argue, LOOK, and believe. Because it's TRUE.
That however IS potentially true. Not all cars had electric fans; from 1955 until 83 or so, NONE did. Even after that, it was MANY years before ALL did. A car without electric fan won't have the wire, and won't have the switch it would plug into (although the place in the head that the switch would go, has been in EVERY head since 1955). Specifically, LG4 (base model V8) F-body cars didn't have electric fan provisions, because their fans weren't electric to begin with.
Why are you arguing this thing? What are you trying to do? If you'll stop arguing stuff that isn't true, and ASK NICELY what goes where or what to do or whatever, maybe we can help.
Old Sep 24, 2021 | 02:32 PM
  #60
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Maybe its covered in crud and can;t be seen? I think its an inverted hex plug or something..... Some engines are ridiculously dirty and caked in crud....spray the area with brake cleaner or take a towel and wipe the area. Youd see a fan switch if you had one though.... if it fell lout, your coolant would pour out and your motor would be toast!
I recall hearing 85 - 86 used a ecm fan control and no fan switch for electric fans...so youd have no fan switch....but like Sofa said there are holes / plugs there regardless.
Foster382
Apr 30, 2010 12:15 AM
Crazy 84 Z28
Jul 24, 2007 09:10 PM
ScottyRS
Mar 6, 2007 08:36 PM
86irocboss
Mar 10, 2005 09:04 AM
chevy35086
Sep 4, 2004 04:47 PM
