Custom Engine cooling system
Old Jun 24, 2010 | 08:39 PM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
I was watching musclecar a few months ago when I remembered one of the mods they did. They took this monte Carlo (has pretty much the same headlight setup as the camaro) where they removed the outside headlights and hooked up hoses where they put the air filters and they ran them up to the airfilter on top the engine. I was wondering if I could the same with my TPI engine and if it would help my engine run cooler and if it would make my car have increased power. So the hose would start at the spot where the headlight was removed and they would both go in the TPI as shown in this picture.
Old Jun 25, 2010 | 01:02 AM
jlanham's Avatar
Car: 1987 IROC Z28 1le brakes
Engine: switching to 383
Transmission: installing tko 600
Re: Custom Engine cooling system
you would still have to keep your MAF on non speed density camaros
Old Jun 25, 2010 | 01:53 AM
the solitaire's Avatar
Car: '89 RS camaro 305 TBI
Engine: LO3
Axle/Gears: yep, has those too (stock)
Nope, it wouldn´t make the engine run cooler. Allit would do is get more air into the engine where with TPI this shouldn´t be your main issue.
Small gains maybe, nothing worth your while if the rest of the intake is stock though.
Best keep your current intake system and consider E-fan setup (maybe with shroud) and modifications to your airdam, as well as finding ways to extract heat built up under the hood.
Please also consider that the engine has a rather high operating temperature, which was designed this way by GM.
Old Jun 25, 2010 | 09:41 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
The factory fans on the 87 IROC are very effective. I know, I run 470hp on them with no issues. If you want cooler temp, change the thermal fan switch to a lower temp. Search threads on this forum for the part#. I think it is GP Sorenson FTS6, but its on here somewhere.
As far as ram air, which is what youre talking about. It will not cool the motor. It is intended to increase power by creating pressure at the throttle body. It is a worthwhile endevour but you will have to figure out how to incorporate you MAF into it. Or spend big bucks and go speed density like I did. Then spend lots of time tuning with your laptop.
For a really cool ram air setup, look for Ibad91Z on here. Hes created the coolest ram air Ive seen yet, and a high flow air box lid to go with it. Very cool. The IROC lends itself quite nicely to this design. 1bad just beat me to it cause hes a big jerk and I hate his car too. JK
Fast355
Dec 2, 2016 06:33 PM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
TheExaminer
Aug 26, 2015 04:59 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
