Carb'd motor running hot
Old Jun 25, 2010 | 03:06 PM
tomtom420's Avatar
Car: 86 Grand National / 90 Formula
Engine: 3.8 V6 / Procharged 5.7tpi
Transmission: 700R4 / 700r4
Axle/Gears: 3.42's / 3.23's
Recently just finished my iroc and now the motor seems to be getting hot. I have the fans wired so they are always on(dual fans). I have a brand new radiator 50/50 mix and 160 degree thermostat. The water pump is just a stock one. The block is a mid 70's 350, it has full length headers and my temp sensor goes into the driversside head. I was wondering if the headers are giving of so much radiant heat that its giving me a false reading at the gauge. It will get up to 230-235 degrees, in my opinion that seems way to high. Any info would be great. Thanks
-tom
Old Jun 25, 2010 | 03:39 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: Carb'd motor running hot
Are they dual stock fans? If so, I had absolutley no luck with them at all. I eventually got a stock fan off a 95 (?) Lincoln Mark VIII. It moves a massive amount of air and solved all my problems.
Old Jun 25, 2010 | 05:13 PM
tomtom420's Avatar
One is stock the other is some advanced bs. they both came with car, are you running one or two fans from the lincoln. You don't think the location of the temp sensor is an issue?
Old Jun 25, 2010 | 05:27 PM
one92rs's Avatar
Car: SOLD!!!!!
are you running the late model water ppump on that engine or the older one.
Old Jun 25, 2010 | 05:34 PM
ymenic's Avatar
Car: 1982 Camaro z-28
Engine: 307
Transmission: th-350 with stage 2 shift kit
Axle/Gears: stock
160 degree thermostat is a little low, you should get an 180 better for performance. Is it overheating while driving on the highway or in town? Do you have your fans going the right way? It could be your timing is not set right also?
Old Jun 25, 2010 | 08:09 PM
built91Z28's Avatar
I'm only running one. The fan is a 16" fan and the shroud is only a few inches smaller than the stock radiator. Two could probably cool a big diesel. I dont think the location of the sensor is a problem. Thats where it is factory. As asked above, are you sure you have the correct water pump for you accesory setup? Also the tune on the motor can cause overheating.
Old Jun 25, 2010 | 10:17 PM
tomtom420's Avatar
Yea I've been thinking it was the water pump or the tune. It has a factory water pump, i don't know exactly what year its from but its older, possibly as old as the block. As far as the tune what i really think is going on, is that i'm running to lean might have to bump up some jet sizes. The timming is set at 12 degrees advanced, the car runs and drives awsome just gets hot during stop and go traffic and when you get on it repeatedly. The carb is a holley 650 dp that hasn't been tampered with. The car also has about 10:1 - 10:5:1 compression. So i'm hoping its just a lean situation or a water pump going bad. Please more questions though i apperciate the help.
-tom
Old Jun 25, 2010 | 10:23 PM
built91Z28's Avatar
Are you running an older (pre 86) water pump with the stock serpentine system off your 88?
Old Jun 26, 2010 | 12:49 AM
tomtom420's Avatar
The car does not have a serpentine set up, it has a v belt. The water pump im not sure of the year but looks older than 86.
-tom
Old Jun 26, 2010 | 01:07 AM
cxxm's Avatar
Car: 1984 Trans Am
Engine: 305 L69 (E4ME)
Transmission: NWC T5 1352-072
Axle/Gears: 3.73 (6HS)
I was overheating going down the road reaching 220-230F over 35 mph. Turns out my problem was the air dam/spoiler that hangs a few inches below the radiator. A senior member explained to me that it creates a low pressure area behind the radiator causing air to be pulled through it. Once I put the air dam/spoiler back on my car it did not go over 190F at 45-75 mph and the fan never came on. The outside temperature was in the 80's. The stock fan took care of the temps at idle. I have a Trans Am, but have seen them on Camaro.
Old Jun 26, 2010 | 01:29 AM
tomtom420's Avatar
Yes thats there, my buddy actually had the same problem like you were describing with his lsx 6.0 swap so i checked that immediately. Thanks for the info
-tom
Old Jun 26, 2010 | 08:28 AM
one92rs's Avatar
Car: SOLD!!!!!
-tom
if it is a vbelt on it then you are ok. the year of the car suggested a serpintine system.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
86IROC112
Aug 17, 2015 02:00 PM
