AC air intake?
Old Jun 28, 2010 | 03:19 PM
BigBadGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 350TPI
Axle/Gears: 3:27
AC air intake?
Where does the A/C take in the air from? I was wondering today because I know on new cars they have the option to recirculate the air. thanks
Old Jun 28, 2010 | 04:03 PM
icantdrive55's Avatar
Car: '89 RS vert
Engine: 305 TBI
Re: AC air intake?
All interior air--whether heated or cooled--comes into the airbox from the cowl vents on the top of the firewall in front of the windshield. If you have AC, the Max-AC setting should open an interior door which will draw a percentage of the total air being moved thru the box from the interior down under the passenger side dash. This boosts the AC efficiency because you are recirculating air that's already cooled and dehumidified.
Old Jun 28, 2010 | 04:04 PM
885speed's Avatar
Car: 1988 Camaro
Engine: LR4
Axle/Gears: 3.23posi/disc
Re: AC air intake?
I've been told that when on MAX, it recirculates. Not 100% sure though. The a/c takes air in from infront of the windshield.
Old Jun 28, 2010 | 04:31 PM
BigBadGTA's Avatar
Engine: 350TPI
Axle/Gears: 3:27
Re: AC air intake?
Ok thanks guys! I always wondered what the difference between A/C and MAX A/C was. I thought it was a pretty inefficient system if it grabbed all exterior air. What got me thinking of this was because I was on the freeway today it was 108 outside and I had it on the normal A/C, and it got pretty damn cold so I was wondering where it grabbed the air from. My system was filled up with R12 last year so it works damn good.
Old Jun 29, 2010 | 11:44 AM
885speed's Avatar
Car: 1988 Camaro
Engine: LR4
Re: AC air intake?
Our ac system seems to be pretty good for how old they are, I plan on overhauling mine to get it to blow a little harder and colder. 2-45 ac doesn't work as great in Florida summers.
Old Jun 29, 2010 | 01:26 PM
b4ccamaro's Avatar
Car: 92 1LE B4C
Transmission: 4L60
Axle/Gears: 4th gen 3.42
Re: AC air intake?
I live in AZ and our ac systems SUCK!! They don't do the job in the summer.
Old Jun 29, 2010 | 09:01 PM
885speed's Avatar
Car: 1988 Camaro
Engine: LR4
Re: AC air intake?
Whats the average temp during summer over is AZ?
Mine usually cools the car off to a comfortable level after about five-ten minutes, in 90-95 degrees of heat.
1992 Trans Am
May 10, 2023 07:19 PM
stalkier
Dec 6, 2015 11:25 PM
kyle5647
Aug 15, 2015 11:56 PM
Jake_92RS
Aug 11, 2015 10:39 AM
