AC needs recharging... solution besides taking it to a shop?
Old Jul 9, 2010 | 07:19 PM
Gabaloo's Avatar
apparently its pretty spendy to have a shop recharge my old AC. like 400 bucks. is there an altenative to getting robbed just for my AC to work?
i see things like this: http://www.amazon.com/Freeze-12-Full.../dp/B002GTGUYS
upon googling, but i dunno if i trust it.
it is a 91 z28.
Old Jul 9, 2010 | 07:37 PM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Axle/Gears: BW 9-bolt 3.27 posi
Re: AC needs recharging... solution besides taking it to a shop?
I believe other guys on this board have used it with success. Before you try it, are you sure that all you need is a recharge? If your system is leaking, you will just waste time and money recharging it without fixing the leak.
I highly recommend doing a search in the cooling forum to see what you can find out.
Old Jul 10, 2010 | 02:13 AM
Gabaloo's Avatar
no i am not sure, is the only way to test for leaks to take it to a shop? i did a bit of searching and reading, but a lot of the threads are like three years old.
Old Jul 10, 2010 | 04:05 AM
Gabaloo's Avatar
well i got my Section 609 MVAC Technician Certification, so i guess ill just buy me the r12
Old Jul 10, 2010 | 07:08 AM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
The best way to check for leaks is to evacuate the system with a vacuum pump and see if it holds vacuum.
Before I did that, though, I would try to determine the state of the charge. If it just needs 'topping off', there probably is no reason to do that... but if it is essentially empty, you should do the vacuum check.
Old Jul 10, 2010 | 11:46 AM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
you can rent all the equiptment at autozone, they also have a video with alot of good info for ac
86IROC112
Apr 9, 2016 10:20 PM
project89
Sep 24, 2015 06:38 AM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
Kevin91Z
Sep 16, 2015 03:00 PM
neekolzun
Aug 24, 2015 04:59 PM
