odd problem, system holds pressure forever
Old Jul 11, 2010 | 05:25 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
ok, maybe not forever, but the cooling system in my car holds pressure for way too long, for instance, i have not touched the car in 2 weeks, and when i took the radiator cap off this afternoon, it blew coolant everywhere. It does this all the time.
Im at a loss as to why.
any ideas? the radiator cap is 16lbs
Old Jul 11, 2010 | 06:10 PM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
Re: odd problem, system holds pressure forever
wow, interested as to what would cause this too!
Old Jul 11, 2010 | 06:19 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Think I'd start with a new radiator cap. The radiator caps where out. They have a spring loaded valve in thm that is supposed to release pressure vis releasing some coolant to the overflow bottle. Then, through suction the coolant is forced back into the radiator as it cools. That's why the bottle has a hot line higher on the bottle than the cold line.
Old Jul 11, 2010 | 06:23 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
im going to try that, but coolant does travel from the overflow, and back too i assume. the lvl changes. the cap is maybe 5 years old, but who knows.
Old Jul 13, 2010 | 05:32 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
ok, so i went over things, and from what i could tell, the vent on my overflow cap was not working, so i made a new baffle for it. This afternoon, i had no pressure in the system. I changed the radiator cap anyway, and will see tomorrow if it again properly bleeds the pressure off.
bad news, the pressure pushed 2 freeze plugs just enough to get them to weep, fixed one, the other is by the oil filter. ITs a little tight in there, so i just tapped the plug a few times, hopefully it will reseal, if not, its not going to be fun changing that one.
Old Jul 17, 2010 | 02:17 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
the problem was that the overflow cap was not venting, i vented it and everything is normal, so far, the water leaks have stopped.
Ghettobird52
Jul 5, 2024 11:18 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
backtothe80s
Sep 5, 2015 12:39 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
