coolant catch can question
Old Jul 16, 2010 | 12:10 PM
Blue383's Avatar
dumb question, i dont have a return line for my catch can, would excess pressure build up in the rad if the can gets full of coolant? would draining the can for now and pouring it back into the rad be a problem?
Old Jul 16, 2010 | 05:57 PM
b4ccamaro's Avatar
Car: 92 1LE B4C
Transmission: 4L60
Axle/Gears: 4th gen 3.42
Re: coolant catch can question
If you mean the radiator overflow then no there wont be excess press build up in the radiator if the overflow is full. The overflow will just.... well overflow it there is too much coolant. It would be ok to reuse the coolant if it doesn't get contaminated with anything.
Old Jul 17, 2010 | 11:42 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
There is only one line to any coolant overflow. It works by suction - like when canning vegetables - the heat in the radiator cooling down creates a vacuum that sucks the coolant back out of the overflow - that's why there is a hot and cold mark on the overflow - when the system is hot it will be fuller, when it's cold it will be less. This is all controlled by the radiator cap - as pressure builds on the radiator cap it is spring loaded like a thermostat and it "opens" up, allowing coolant to flow to the overflow. When the system cools down, a suction is created and coolant returns to the radiator. That's why there are different pressure ratings available in radiator caps.
Bstrang6
Sep 8, 2015 04:29 PM
someone972
Aug 30, 2015 12:52 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
TheExaminer
Aug 26, 2015 04:59 PM
redmaroz
Aug 16, 2015 11:40 PM
