Modified 305 Cooling issues
Old Jul 21, 2010 | 09:34 PM
inkjet2's Avatar
The basics
85 T/A with 305
Emissions removed
new holly 590cfm double pumper
new dist
new radiator
new water pump
straight water (temporary)
all new hoses
new stat.
exhaust has no cats and is true dual with packs.
engine runs and idols perfectly.
Top cowel on, lower cowl still off.
BUT OVERHEATS WITH OR WITHOUT THERMO
TOP AND BOTTOM HOSE GET HOT. OVERFLOW FUNCTIONS.a
any suggestions?
Old Jul 22, 2010 | 10:13 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Modified 305 Cooling issues
1) You mentioned new water pump - got the right one? V-belt cars had a standard rotation, serp belt cars get a reverse rotation - what belt system are you running?
2) When is it overheating? Intown or on highway?
3) Fan working?
4) Have you tried a new radiator cap?
Old Jul 22, 2010 | 03:38 PM
inkjet2's Avatar
update
The pully is v groove and the fan is non clutch.
Water pump appears to be functioning as the water flows quite rapidly on visual inspection under cap.
With thermostat removed, the engine rose to 185 in about 5 minutes of conservative city driving. Once on an open road and accelerating to about 70, the temp shot to about 240. It returned to 220 while idling for 5 minutes. During 15 minutes of 30mph the temp held. A short speed up to 60 rose the temp to 225, where it stayed even at slower speeds.
I plan to drain the system and install new coolant and try again. Howevr, I am beginning to think the modifications with force a more robust cooling solution.
Old Jul 22, 2010 | 03:59 PM
Car: 1992 RS
Engine: Carbed 350
So it's heating up on the highway - sounds like the air dam is missing - supposed to be right under radiator, plastic piece about 3 ft long and 4 inches wide. Car will overheat at highway speeds without it - fans do no good at all above 40mph. If it's missing, get one, make one, whatever.
Old Jul 22, 2010 | 07:32 PM
inkjet2's Avatar
thanks for that information. Yes I did remove the spoiler. I will intall the lower cowel and spoiler in am and post results.
Old Jul 23, 2010 | 01:38 PM
inkjet2's Avatar
I reinstalled the lower fan cowl and the air dam which bolts to the radiator support. Car holds perfect temp, slow, fast, or four barrel speedy. Thank you.
Old Jul 23, 2010 | 01:40 PM
Car: 1992 RS
Engine: Carbed 350
Glad it worked out!
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Street Lethal
Apr 30, 2019 12:14 PM
theurge
Aug 21, 2015 12:46 PM
Leggman1
Aug 6, 2015 04:15 AM
