A/C Doesnt Cycle
Old Jul 28, 2010 | 02:33 PM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
A/C Doesnt Cycle
Well I wanted to know if my ac system worked at all, since it hasnt since i got the car. i put a charge on it and the comressor wouldnt work unless jumped, no matter what. i found a bad connection in the cycle switch.
i installed a new switch and now the compressor stays on, no matter what, as long as the ac is on. it doesnt cycle, just remains on. what can cause this?
Old Jul 28, 2010 | 06:28 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: A/C Doesnt Cycle
Where do you live? Keep in mind, most vehicles won't cycle at this time of year.
The low pressure switch is probably adjustable. Take the plastic connector off and look between the two electrical prongs. If it's adjustable, there will be a tiny screw in there. Turn it clockwise to turn the cycle off psi higher (cycle more often)
jrdturbo
Mar 31, 2016 02:58 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
BLK87Z
Sep 18, 2015 11:29 PM
Mdenz3
Sep 17, 2015 08:36 AM
