New engine, new computer, overheating
Old Aug 23, 2010 | 08:24 PM
meyer30's Avatar
Car: 1992 T/A
Engine: 5.7l 355
Transmission: 4L60
Well I finally got my motor running and the Holley Dominator efi is tuning nicely, but today when I went to get the exhaust finished when I'm sitting at a light it starts to overheat. I do not have the TB coolant lines hooked up but I'm not sure if I bypassed it correctly. Could that be causing problems if it's hooked up wrong? I'm using a 180* thermostat, stock fans (which do come on) and the radiator is full. My timing at idle w/advance is 25*. Any suggestions on where to start to find my problem?
Old Aug 23, 2010 | 09:11 PM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
Re: New engine, new computer, overheating
Did you make sure there weren't any air bubble's in the system? I had that same issue but with an Tbi firebird.
Old Aug 23, 2010 | 09:20 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Do you get heat from the heater core? If not you may have an air lock caused by air trapped in the system or a flow problem caused by misrouted hoses. One trick I always use is to drill a 1/16 hole in the thermostat for air bleed, unless the thermostat already has an air bleed.
Old Aug 23, 2010 | 10:22 PM
affliction1's Avatar
Car: 89 chevy camaro rs
when its running squeeze the radiator hose for a while with rad cap off should push bubbles out
Old Aug 23, 2010 | 11:08 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I know nothing about the Holley EFI system, but to me 25* sounds like way too much timing, and timing can greatly affect heat.
Old Sep 12, 2010 | 07:34 PM
mike f's Avatar
Car: 1987 camaro
try to set the time to 8 or 10 see if still over heats i had the same proplem with my new
motor over heating when driveing a jot of things wrong with the tpi so i am takeing off
and puting a rockchester on it such have to figure out how to hook up the gas lines and the heater hoses
sweet_87_iroc
Sep 25, 2015 10:01 PM
mustangman65_79
Sep 1, 2015 03:51 PM
E Rod
Aug 28, 2015 05:17 AM
Bryan F
Aug 18, 2015 02:28 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
