Help overheating
Old Aug 24, 2010 | 07:10 PM
PAIMON's Avatar
Car: 1989 Camaro RS Convertible
Engine: Need help identifying
Help overheating
So I replaced the thermostat and today I took it out for a ride
I didn't drive even ten minutes
While I was driving I heard clicking
When I finally stoped and parked all the water Came out
What should I check?
Old Aug 24, 2010 | 07:17 PM
spade's Avatar
Car: 1989 Mystery Firebird
Engine: 350 FIRST TPI
Re: Help overheating
where did all the water leave from?
check all your hoses
Old Aug 24, 2010 | 07:19 PM
spade's Avatar
or a crack on the radiator
Old Aug 24, 2010 | 08:21 PM
PAIMON's Avatar
From the radiator cap I thnk
Old Aug 24, 2010 | 08:27 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Replace the cap.
Are you running a 50/50 mix water/antifreeze?
Are the fan(s) coming on at all?
1 or 2 fans?
TBI (looks like a carb) or TPI?
Is there an air dam bolted directly under the radiator?
Old Aug 24, 2010 | 08:53 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Do you have a V8 or a V6? Is the air cleaner housing a big round black one that looks just like what cars have always had? You said all the water came out. Was it pouring out at a good rate from anywhere in particular, or was there lots of steam coming from somewhere? Was the car working OK before this happened, and what made you want to change the thermostat? Not being nosy or trying to bug you, but the more info the better we can help. Oh, and DONT add more water and try to run it again until it's completely cooled down.
Old Aug 24, 2010 | 08:54 PM
PAIMON's Avatar
Tbi
One fan always running
Old Aug 24, 2010 | 09:06 PM
PAIMON's Avatar
V8
I checked and theradiator was full
Also from the coolant tank
The car had been without driving for almost a year cause I had been working on it
I changed the hose n thermostat cause the hose was ripped
Thanks for the help
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
mustangman65_79
Sep 1, 2015 03:51 PM
JHX
Aug 29, 2015 02:30 PM
jbd1969
Aug 17, 2015 07:06 PM
