CFI water outlet/thermostat housing
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
hi all I cannot find a crossfire injection water outlet/thermostat housing. Every one I found does not fit the hose neck angle is way off.(napa, oehq, rock auto, and etc) it keeps hitting the a/c compressor.
Re: CFI water outlet/thermostat housing
is it the same as on the corvette???
no it is not the same as the corvette it is a different gm part number
Bump
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
i'll check if I have a spare-last time you were looking I didn't have one,but I have obtained a few more spare crossfire sets since then...
