Jow much of a difference does a fan shroud make on a radiator
Old Sep 15, 2010 | 04:33 PM
THETANK's Avatar
Car: 91 rs
Engine: Carbed 355 CR 9:1 xr276 cam
Transmission: 700r4 2600 stall
I was looking at these two radiators specifically and was wondering how much of a difference the one with a shroud makes cooling wise? Is it worth the extra $120?
http://cgi.ebay.com/ebaymotors/RADIA...Q5fCarQ5fParts
http://cgi.ebay.com/ebaymotors/ALUMI...Q5fAccessories
I know champion radiators have been discussed before and was wondering which one of these two you would opt for?
Old Sep 15, 2010 | 04:36 PM
Twin_Turbo's Avatar
Re: Jow much of a difference does a fan shroud make on a radiator
links don't work but a shrouded setup allows the fan to pull air through that part of the core than is spanned by the shroud. With a fan up against the core it only pulls from the surface spanned by the fan
Old Sep 17, 2010 | 11:39 AM
b4ccamaro's Avatar
Car: 92 1LE B4C
Transmission: 4L60
Axle/Gears: 4th gen 3.42
In that set up I wouldn't bother with the shroud. If you are looking for better cooling, get the fans and shroud off of a 98-02 firebird or camaro. I just installed them on my 92 camaro and they will keep me at temp all day long in the Arizona summer. All of my overheating problems are over. The fans plug right in with your original harness. I have just the original radiator too. Pm me if you want info and pics on the install.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
RazorN8
Jan 7, 2022 11:44 AM
onefreakz
May 14, 2018 12:15 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
