Fan Shroud - V-8 Vs. V-6 ?...
Old Oct 18, 2010 | 04:56 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Is the mechanical fan shroud for the V-8 different from the V-6? I'm gonna be p!$$$d if they're the same. 'cuz I threw a V-6 shroud away...
Old Oct 18, 2010 | 11:56 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: Fan Shroud - V-8 Vs. V-6 ?...
w/o digging out a collision book, I'd say different since the v6 sat further away.
the v6 and duke (l4) probably used the same shroud though. i would also doubt the 6 using the same dia. fan as well from a rotating drag standpoint.
Old Oct 18, 2010 | 11:57 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
good news-the v-6 shroud is way different from the v8
shrouds
Also camaro and firebird are different-the firebird v8
shrouds have a smaller fan housing and use a 17"fan
in order to provide more clearance for the firebird's
more sloped nose. The camaro version uses an 18.5"fan.
-This is for '82-85 belt drive v8 fans...
Old Oct 19, 2010 | 12:04 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Without looking at the book, I'd guess that the V6 was different, but the V8 and L4 used the same fan, since the blocks are both 4 cylinders long.
The V6 fan might have been the same diameter, but the blade count, pitch, or clutch could have been changed to deal with the drag.
Old Oct 19, 2010 | 12:16 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
I have seen 3 different styles of '82-84 v-6 fans,'82-83
A/C-5 blade clutch,'84 A/C-3 blade deep pitch clutch,
'82 non-A/C-4 blade,rigid non-clutch.
Old Oct 20, 2010 | 12:46 AM
T.L.'s Avatar
shrouds
Great......I just bought a Camaro fan from a forum member. So I guess it's gonna be too big for my Firebird...
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
Mark_ZZ3
May 24, 2018 01:02 PM
383backinblack
Oct 14, 2015 08:50 PM
Fanatic1074
Oct 2, 2015 03:47 PM
