Main Seal
Old Oct 22, 2010 | 12:39 AM
Shadow_GTA's Avatar
Car: 1988 GTA Trans Am
Engine: 350 5.7 L
Axle/Gears: Posi Rear WS6
Main Seal
Would my car running above 220 cause my main seal of the oil pan to start a leak. If so fml...
Old Oct 22, 2010 | 12:54 AM
Mrs.Crasher0083's Avatar
Car: 88 Pontiac GTA and 4 Camaros
Engine: 5.7
Re: Main Seal
Id say yeah. I know in my 88 GTA if the oil is low...the temp goes up. I have a leaky rear main and I know when its time to add more oil because my temp runs hot. Does it run hot when the oil level is good? If not....the problem might be in the cooling system.
Old Oct 22, 2010 | 12:56 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Main Seal
Not really
Old Oct 22, 2010 | 08:20 AM
Engine: 5.7
Re: Main Seal
Check and fill the oil level as needed and then see if it runs hot.....If it dont run hot....your oil level isnt the cause of the elevated temp. If it runs hot and the oil level is good.....Its most likely a cooling related problem. Low oil CAN make an engine run hotter then normal. So can low trans fliud.... this is a fact.
Old Oct 22, 2010 | 09:26 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Main Seal
High, low, hot, cold, whatever... it's not going to make the RMS leak.
Old Oct 22, 2010 | 09:39 PM
Shadow_GTA's Avatar
Engine: 350 5.7 L
Re: Main Seal
my temp gauge dont work so im skating on thin ice and im doing a oil change tmrw morning, hope for the best...
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
Dragonsys
Sep 25, 2015 03:51 PM
