Heater blowing cold air
Old Dec 9, 2010 | 08:29 AM
SC87'GTA's Avatar
I leave my house this morning and the heat is working just fine. I pull into the parking garage and sit at idle for a bit and notice there is no longer hot air blowing, its all cold. I read on a a general car message board that it could be low coolant. I've also read that if I touch both hoses and one is cold then its a clogging issue. Are these to two basic things I should start with before I take it to the mechanic?
Old Dec 9, 2010 | 11:50 AM
Flightoficarus's Avatar
Re: Heater blowing cold air
Is there any coolant leaking into the the interior around the the front floors at all? Check the hoses first. If those are good, you may have a bad heater core.
Old Dec 9, 2010 | 12:11 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
start with checking the hose, check your coolant levels, and (the harder part) check to make sure your temperature vent door is not stuck.
another thing that comes to mind - heater bypass valve on the passenger side; this may be stuck in "a/c mode" and not allowing coolant to circulate through the heater core
Old Dec 10, 2010 | 07:37 AM
SC87'GTA's Avatar
Alright, so I get back into my car and leave the parking garage and the heat works. Same thing this morning, start my car, heat works on my way to work but when I pull into the parking garage it turns cold. The only thing that is constant with both days is the engine temperature is running a little hot when the heat turns into cold air. Any thoughts on that? Thanks!
Old Dec 10, 2010 | 11:35 AM
KnightmareCS's Avatar
Car: 82,83,99 T/As
Engine: 350,350,383
Transmission: ST-10,700r4,4l60e
Axle/Gears: P-3.23,P-3.42?,P-4.10
After reading that, I think it's this:
Or a clogging heater core.
Old Dec 10, 2010 | 11:53 AM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
my old S10 did the same thing.....I had to back flush the heater core....fixed the problem...tons of junk came out of it...
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
hayesaw0210
Aug 23, 2015 11:15 PM
kyle5647
Aug 15, 2015 11:56 PM
jackhammer
Aug 15, 2015 10:04 PM
