Dual fans from stratus and Flex a lite variable speed controller
Old Jan 5, 2011 | 07:00 AM
Nonni's Avatar
Car: 86 T/A
Engine: ZZ383
Transmission: TH700R4 Raptor
Axle/Gears: 2,7x -> 3.00 or 3.50
This summer I drove my TA for the first time after a complete overhaul. It has ZZ383 and I did buy a summit aluminum radiator and an auxillary cooler for the trans (Stacked plate). It had a single fan (not the stock one, I am sure this is smaller, did only cover half of the radiator). At the first drive the temperature was alwais getting higher and higher, even with the fan on. I dit turn the engine of when the temp was over 220 F (I know that heat is ok but because the temp was rising and the fan was working overtime trying to cool the engine I saw no point in keeping it on).
I suspected the fan but had no time to work on it then so I put the TA back into the garage
Since then I have installed a stratus dual fans and a Flex-a-lite Variable Speed Controller for the fans and it cools my 383 really fast! Usually it stays on for about 1-2 minutes and after that it turns of again. Needles to say it solved the problem completely, now the engine never get past around 185 F. I also installed a temp gauge for the trans and the TH700 stay at 150 F. So I can recommend those Stratus fans, there are lot of the them out there and they are really cheap
Just wanted to share
Old Jan 5, 2011 | 06:24 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: Dual fans from stratus and Flex a lite variable speed controller
i used ls1 fans and a flexalite controller. love the way the controller turns them on softly and runs at 60% then goes to 100% only if needed.
Old Jan 8, 2011 | 04:03 PM
Nonni's Avatar
Car: 86 T/A
Engine: ZZ383
Yeah, they are great
eightsixseven
Dec 16, 2024 01:50 PM
Scamo-2.8
Dec 5, 2015 09:16 PM
krisner89
Oct 10, 2015 06:03 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
hayesaw0210
Aug 23, 2015 11:15 PM
