Radiator Cap Problem's
Old Jan 12, 2011 | 08:58 PM
Guest
Guest
Posts: n/a
Well some guy put a aftermarket radiator in my car. 91 v8 anyway get to te point. there was a 13ib cap and the rubber was all dry rotted and cracking.
Would that cause the car to run at 240 degrees all the time. resivoir tank fills fine also replace thermostat to 180 stock recommended stat also new resivoir bottle. Old one full of soute. Also flushed twice haven't had it running long enough to see if the car will get up to a high temp with the new 16ib cap and thermostat and flush.
Tell me if you think this fixed my problem at least for now if you might know.
Thanks.
Old Jan 13, 2011 | 07:55 AM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
Re: Radiator Cap Problem's
The cap shouldn't cause the car to run hotter (unless its actually leaking/letting steam out), it just keeps the system from boiling until it gets to about 250 degrees or so( increased pressure = increased boiling point). Make sure your water pump is circulating and there is no air in the system.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
Ron U.S.M.C.
Sep 7, 2015 08:38 AM
lakeffect2
Aug 23, 2015 08:44 AM
