No heat or a/c
Car: 1990 camaro rs
Engine: 5.0
No heat or a/c
I have a 1990 chevy camaro that has no heat or a/c. During the summer when I turned on the a/c the heater core started leaking into the car. Since I had no a/c did this cause my heater core to go?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: No heat or a/c
If at anytime your heater core leaked, then it needs replaced. Won't solve the A/C issue, but a leaking heater core can make the car overheat and create a real mess in the pass floor board.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Hard Core
Does the blower run?
Happy Racing!
I Hit The Water Barrels Because My Car Was Dirty
Happy Racing!
Car: 1990 camaro rs
Engine: 5.0
Re: No heat or a/c
The car doesn't overheat I took care of that issue but and I no the heater core needs to be replaced just wondering if they r related cause turning on the a/c made the heater core go bad
