foam in radiator
Old Jan 21, 2011 | 04:53 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
foam in radiator
My radiator gets foam in it. Not a lot just on surface and it goes away few moments after shutting off car. I read through ohter threads. Some say head gasket, some say intake. Some say exaust. I would like to know how to tell which one. No water in oil. No oil in water. Does not overheat really. But when I crank over ingine it like burps out with each crank. I don't know if I should flush and replace all hoses. it is just odd. It is like it just has a lot of pressure in system
Old Jan 22, 2011 | 04:29 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Re: foam in radiator
If its burping out with each crank it may be getting combustion chamber gasses (or compression) in there. Head gasket.
You can get a block test kit from Crapa (or is it Napa) auto parts.
You fill a tube with a blue liquid, press one end to the radiator neck (helps to have the coolant level down) and with a suction bulb on the other end, draw the air into the tube. If the liquid turns yellow there are combustion chamber gasses present.
Old Jan 22, 2011 | 04:55 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Sweet. I will check it out. Then if head gasket it must be a small crack cause no other signs.
Old Jan 22, 2011 | 05:08 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Look closely at your gaskets. You should be able to see between a wate rjacket and a cylinder where its leaking. If you see something that is good. Also look closely at your heads. If cost is not a big factor then it may be a good idea to take them and have them checked at a machine shop.
sheachopper
Jul 31, 2019 11:27 AM
lanceflame44
Sep 25, 2015 12:28 PM
