A/C Condenser/Radiator Core support removal?
Old Jan 30, 2011 | 08:42 PM
Flightoficarus's Avatar
So, after much frustration with trying to get my Champion radiator to fit in my car, and wasting plenty of time shaving down the rubber isolators, I've come to find out that my radiator core support is bent, from a previous vehicle jacking
It's too bent to simply hammer out, so it looks like I'm going to need to rip it out and put a good one in it. I'm curious about the process of removing the A/C condenser before I start unbolting stuff though. It seems like anything about it in the Hayne's manual tells you not to service it yourself, and that refrigerant is dangerous, blah blah blah...I'm just curious if there is anything else I need other than basic hand tools to remove it? Or if I should take any precautions over refrigerant that might spill out upon unhooking hoses? (other than having a container for it to pour into).
Thanks in advance for any help!
Old Jan 30, 2011 | 08:58 PM
CamaroIROC88350's Avatar
Re: A/C Condenser/Radiator Core support removal?
You'll need some basic hand tools like a wrench for example. I know, I know, it sucks.
Honestly, it's against Federal law to unhook any of those condenser lines as they have the refrigerant in them and releasing it into the air is a major offense. Plus I don't think mother nature appreciates it.
When I removed my ac condenser last summer I had my mechanic drain out all of the refrigerant and to do that should be free at any shop. Then you can take it out and do what you want with it. But here's a video of me discussing my removal of my ac condenser. Thanks.
http://www.youtube.com/watch?v=FcdlQ...layer_embedded
Old Jan 30, 2011 | 09:25 PM
Damn..Hmm, well, what should I do? The stock radiator and water pump are both toast, so driving the car isn't an option. Would it be too much of a PITA to try and work around the condenser? or is it possible to have a mechanic come out to it and drain any refrigerant? because driving the car simply isn't an option ATM :/ I was told that the A/C needed to be recharged when I bought the car (haven't tried using it), but either way, I'd prefer to avoid the cost of having the car towed if I can.
Old Jan 30, 2011 | 09:30 PM
What I would do honestly if you really want/need to do this is go on Craigslist and find a mobile mechanic who can do what you need done. I'm sure someone can as I have used Craigslist to find a mobile mechanic once.
Old Jan 30, 2011 | 11:30 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
10 or20k fine for being caught letting refrigerant into the air. Ya know since the refrigerant is heavier than air it goes to the atmosphere...anyway. calling a mobile mechanic to recover your freon is the best way to go and be legit. Should only charge between 25-45 dollars to evacuate and normally recharge. Plus freon. Some might even give you credit if you have R12 freon.
Night rider327
Sep 2, 2015 04:17 AM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
3rdgenparts
Aug 8, 2015 07:09 PM
