Coolant leak!! No!! SON OF A 81tC#!!!>:(
Old Feb 22, 2011 | 10:00 AM
SanAntonio3's Avatar
Car: 1988 Camaro Iroc-Z
Engine: 1994-1995 LT1 5.7
So I swapped the engine on my 89 camaro. Newer engine is off of a 93 caprice 305ci TBI. I changed the oil gasket, valve cover gaskets, intake gasket, distributor washer, fuel line o-rings, water pump gaskets, hoses, thermostat. Did not mess with head gaskets. Installed a probe thermostat to the radiator for the fan to turn on. Ran the car. Yesterday noticed a leak, looks like coolant coming from passanger side exhaust. Checked the oil, thinking maybe i didnt seal the water jackets right. I heard that if the coolant does mix in with oil, it turns a (brown-chocolate) color. But the oil looks new, and at the correct level. The car does throw white smoke. What could I have done wrong. what did I do wrong? Or what could be wrong with this stubborn car?
Old Feb 27, 2011 | 03:52 PM
Flightoficarus's Avatar
Re: Coolant leak!! No!! SON OF A 81tC#!!!>:(
It sounds like it could be the head gaskets. If there's coolant smell coming from the exhaust, then coolant is somehow getting burned off. That'd be my first suspicion since you said that's basically the one thing you didn't touch.
Old Feb 28, 2011 | 08:47 PM
CHave you ever heard of "Steel Seal". I got a blown head gasket that's causing the leak. I don't, I can't afford to have the head gaskets replaced the right way. I came across that product. Is it good? What can I use? Or do I have to do the more costly repair?
Old Feb 28, 2011 | 08:54 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
anything you pour into the cooling system to seal a leak is a temporary fix at best and usually a bad idea since it can clog the radiator and heater core.
it the leak coming from the exhaust, or from a sensor in the head on that side? or a freeze plug? can you see where the coolant is really coming from?
Old Mar 3, 2011 | 04:58 PM
I'll look at it again, but it looked like the headgaskets, where the head, meets the block, running down the block. When the engine is on, the leak is coming from the exhaust, where the header meets the exhaust. It throws out White smoke from the exhaust too. But I will recheck.
Old Mar 19, 2011 | 12:34 PM
update: bought a pair of rebuilt heads, with valve jobs, head bolt set, head gasket set. Looking for new header bolts, and intake bolts.
Bubbajones_ya
Jul 6, 2024 08:32 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Mark_ZZ3
May 24, 2018 01:02 PM
jrdturbo
Mar 31, 2016 02:58 PM
tattmann
Sep 27, 2015 05:20 PM
